vray bug . hide object
in the work session , hided object be shown.
Hi @hiroki_okamoto ,
We might need more details regarding the issue you are facing.
On a simple test with Rhino Worksessions, all seems fine when rendering hidden objects (they stay hidden) and worksessions are updating properly as well - see attached screen recording: http://ftp.chaosgroup.com/support/sc…8_16-34-27.mp4
Can you share the exact steps so we could try to replicate the issue or even better, send us a recording so we can see what you’re doing. Please also let us know the exact Rhino/V-Ray versions you’re using. Much appreciated!
I have the same issue form time to time. No idea how to reproduce it or why it happen, But in my case it happen with Proxies and VRScene.
For Example, I have an several VRScene on my scene and I hide some of them using the Rhino Hide option (not in layer, but behind the screen) and when I render, the object appear on the render even they are hidden.
Simple test , just turn off layer which has people from chaos cosmos , but appear them in render.
Hi @javierrentas ,
Testing with vrscenes or Proxies, I can’t seem to replicate such an issue either. If you come across it again, do share some steps to reproduce - or even better, if you have an example project file demonstrating the issue, we’ll be very happy to get ahold of that. Much appreciated!
@hiroki_okamoto ,
Still can’t reproduce it even with Chaos Cosmos assets - is there any difference if you Merge the objects before creating the Worksession?
I usually work with big scenes, Full airplane cabins filled with seats. I had to create different configurations of the cabins. So I have a bunch of different VRScene. At some point in the process, the issue will happen.
I need to close Rhino and open the file again to avoid the issue. I’m rendering in GPU. I will make a video if the issue appears again.
It was happened in interactive render.
https://drive.google.com/file/d/1q5q-WWnfNw4jWnXqdfrAWpWKaS4U6JGj/view?usp=sharing
Sorry but the file appears to be empty, maybe using the Pack Project tool from Extensions > V-Ray will be required; also we’d need the .rws file as well.
