Hiding
I know this happened in older builds, but I just hide a group and it still showed up in the render. Unhide, re-hide, still showed up. Deleted it and it’s finally gone.
Build 8
Hiding
Same problem here. This seems to be the same as when using maps and you need to do smth in the scene so that rhino really detects a scene change. If your object doesn’t go away with hiding, hit the material edit button on another object, and hit apply without changing a material setting. That should do the trick.
Hiding
Yes, it seems to be a geometry table problem.
Hiding
I’ll see if I can find a way to detect when a hiding takes place. Right now it will only say the scene changed if a material is edited, or an object is removed / replaced / added. I might be able to find something else though
Hiding
While your at it, maybe find something that detects vray options changes too. Because now when you change a lot of settings, and close, rhino doesn’t ask to save and just shuts down.
Hiding
yes, when anything changes in VRay Options I need to send a message to Rhino to let them knonw the doc has changed. I’ll add that on my list
