Hi, I was wondering if it still possible to use both vray bump and Vray Edge using a VRay CompTex? I can’t get them both work together.
Try using a VRayBumpMtl for the second Bump slot instead.
Hi Hermit.crab,
VRayBumpMtl to the Vray CompTex slot is not possible. It has to be a ‘map’.
That did the trick! Thank you very much.
