ive got to do a cutaway that requires different parts of the scene to be cut at different depths.
ive created 2 selection sets for the different collections of parts, and created seperate vrayclippers.
one is set to do the whole scene, with the 2 selection sets excluded, since most of the scene is at one slice distance.
ive then created a seperate clipper, set to include, for each of the 2 selection sets.
when i render, the whole scene seems to use the main clipper.
help?
its also just stopped working with DR. main workstation is slicing, slave is not.
i think at this stage im going back to scalpelmax, as the viewport feedback alone makes it much less painful to use on a complex scene.
Would it be possible to represent the same setup in a small scene and post it here?
In a simple test everything works as expected.
Are there any errors or warnings in the V-Ray slave log file ?
