Somehow the Vray Plugin does load every time if i open a new scene. Even if i unload the plugin and the scene does not use Vray at all.
There is no way to not load Vray if i opne a new scene.
Im using the new Maya2022 version.
Ok noone has this issue?
Is there a way to find all vray nodes in a scene and delete them?
Its not a good idea to delete the vraysettings node.
I cant save my file now. I get an instant crash.
Doesn’t seem to happen on my end. Usually, V-Ray is automatically loaded only when opening a scene containing V-Ray nodes. Maybe some kind of a default setup with V-Ray nodes is opening?
It seems i cant clean the maya file from vray.
Have you tried the Remove Unknown nodes option (File>Optimize Scene Size>Remove Unknown nodes) with V-Ray uninstalled?
Removing Vray is the solution. ![]()
