vray rt troubles Maya2015 vray3
Waiting on advice aswell
Tried reinstalling. both maya 2015 and vray3. Windows 7. Tried dr, dr local, turning off firewall.
Only vray for maya3 that works with 2015 is a folder install. Maybe a .exe install would help me?
tried rt , rt as viewport, cpu cuda etc.
3 Days trying to get rt working.
V-Ray: Starting render
[2014/Jun/23|15:10:00] V-Ray: Exporting scene to V-Ray.
[2014/Jun/23|15:10:00] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2014/Jun/23|15:10:00] V-Ray: Translating scene geometry for V-Ray
[2014/Jun/23|15:10:00] V-Ray: Total time translating scene for V-Ray 0h 0m 0.0s (0.0 s)
[2014/Jun/23|15:10:00] V-Ray: Rendering with IPR (port 20207).
[2014/Jun/23|15:10:00] V-Ray: Clearing bitmap cache memory…
[2014/Jun/23|15:10:00] V-Ray: Updating frame at time 1.00
[2014/Jun/23|15:10:00] V-Ray: Total time updating frame 0h 0m 0.0s (0.0 s)
[2014/Jun/23|15:10:00] V-Ray: Render complete
[2014/Jun/23|15:10:00] V-Ray: ========================
[2014/Jun/23|15:10:00] V-Ray warning: No image writer specified.
[2014/Jun/23|15:10:00] V-Ray: Preparing renderer…
[2014/Jun/23|15:10:00] V-Ray: Preparing scene for rendering…
[2014/Jun/23|15:10:00] V-Ray: CUDA renderer requested.
[2014/Jun/23|15:10:00] V-Ray: dr host: 127.0.0.1:20207
[2014/Jun/23|15:10:00] V-Ray: Connected to render host 127.0.0.1:20207
[2014/Jun/23|15:10:00] V-Ray: Using 1 hosts for distributed rendering.
[2014/Jun/23|15:10:00] V-Ray: Max ray intensity is enabled: rendered result may have incorrect brightness.
[2014/Jun/23|15:10:00] V-Ray: Running RTEngine
New data index is 0
and from vray
[2014/Jun/23|15:10:00] Reading configuration from “J:\vray_builds\vray_adv_30501
_maya2015_x64\maya_vray\bin\/vrayconfig.xml”
[2014/Jun/23|15:10:00] ===============================================
[2014/Jun/23|15:10:00] V-Ray Standalone, version 3.05.07 for x64
[2014/Jun/23|15:10:00] Copyright (C) 2000-2012 Chaos Group Ltd. All rights reser
ved.
[2014/Jun/23|15:10:00] Use -credits option for additional third-party copyright
notices.
[2014/Jun/23|15:10:00] Build 24658 from Jun 14 2014, 03:46:28
[2014/Jun/23|15:10:00] Compiled with Intel C++ compiler, version 14
[2014/Jun/23|15:10:00] Operating system is Microsoft™ Windows™, version 6.
1, Service Pack 1
[2014/Jun/23|15:10:00] V-Ray core version is 3.05.07
[2014/Jun/23|15:10:00] Loading plugins from “/vrayplugins/vray_*.dll”
[2014/Jun/23|15:10:00] Loading plugins from “/vrayplugins/std_*.dll”
[2014/Jun/23|15:10:00] Finished loading plugins.
[2014/Jun/23|15:10:00] Entering server mode - waiting for render requests on por
t 20207. Press Ctrl+C to exit.
[2014/Jun/23|15:10:00] Starting DR session from 127.0.0.1
[2014/Jun/23|15:10:00] Receiving DR scene from 127.0.0.1
[2014/Jun/23|15:10:00] Reading scene file “C:\Users\DAVIDR~1\AppData\Local\Temp\
vrscene_20207.txt”
[2014/Jun/23|15:10:00] C:\Users\DAVIDR~1\AppData\Local\Temp\vrscene_20207 .txt: d
one [ 0h 0m 0.0s]
[2014/Jun/23|15:10:00] Scene file parsed successfully in 0.0 s.
[2014/Jun/23|15:10:00] Scene created successfully.
[2014/Jun/23|15:10:00] Objects in scene: 0
[2014/Jun/23|15:10:00] Starting render sequence.
[2014/Jun/23|15:10:00] Preparing renderer…
[2014/Jun/23|15:10:00] Preparing scene for rendering…: done [ 0h 0m 0.0s]
[2014/Jun/23|15:10:01] ========================
[2014/Jun/23|15:10:01] Starting frame 1.
[2014/Jun/23|15:10:01] Preparing scene for frame…: done [ 0h 0m 0.0s]
[2014/Jun/23|15:10:01] Compiling geometry…: done [ 0h 0m 0.0s]
Can you describe what is your problem, because is not entirely clear from your post?
Hi, sorry. It was a bunch of different issues.
Support resolved them though. Feel free to delete this thread.
I used, what was only available to me… the vray zip (folders) manual install. All worked well, but rt and viewport rt. I banged my head for days.
I did clean installs, then had license issues, all appeared to install ok using .exe install.
I installed most recent license server from chaos and I am now a happy camper.
Thanks for the speedy response.
Ah, Great it is working now:)
