VrayDirt - object filtering for Work with Transparency
Vlado,
I use VrayDirt with the ambient light quite often. Of course sometimes I run into problems because of transparency and so I have to turn on “Work with Transparency.” When I do that, my render times usually skyrocket.
My question is -- can you make it possible to select which transparent objects it “works” with? I’d like to have a object selection button similar to what you have for Exclude and Results Affect.
