VrayDisplacementMod
Is it possible to use vrayDistanceTex as a displacement map on VrayDisplacementMod?
cheers
Yes, it should work fine.
Can you post the scene as well?
Here is the scene…
GrassDisplacement.zip (6.53 MB)
Thanks for the scene; the VRayDistanceTex texture will only work with the “3D mapping”/“Subdivision” displacement modes. It won’t work with the “2D mapping” mode because it’s not based purely on UVs.
Thanks for the information!
I don’t think I will make grass with 3D subdivision, therefore my workaround will be making a texture instead of using vray distanceTex, although that would be handy!
