I am trying to create a caramel shader using the VrayMTL SSS option and it seems like it is not working.
It should work, can you show us render output or to attach the scene so we could have a look?
Keep in mind that this is strongly dependent on the refraction, which means that your object has to have refraction color different than black. Does this make any difference in your setup?
why is it so complicated in contrast to 3ds max? and why is the translucency option not build in the VRayMtl like in max? we have to use the VRayPluginNodeMtl. It works but the shader is not 100% build in
