Vrayspawner no vraydummy show up on the node
Hy!
the vrayspawner.log gave me this:
0: [2016/Aug/29|20:57:07] ========================== Starting new session ==========================
1: [2016/Aug/29|20:57:07] Got this module name: C:\Program Files\Autodesk\3ds Max 2016\vrayspawner2016.exe
2: [2016/Aug/29|20:57:07] Got this INI file name: C:\Program Files\Autodesk\3ds Max 2016\VRaySpawner.ini
3: [2016/Aug/29|20:57:07] *** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2016\VRaySpawner.ini”. Using defaults.
4: [2016/Aug/29|20:57:07] Dumping current settings…
5: [2016/Aug/29|20:57:07] VRaySpawner temp dir: “C:\Windows\TEMP”
6: [2016/Aug/29|20:57:07] Application name (MAX/VIZ): “C:\Program Files\Autodesk\3ds Max 2016\3dsmax.exe”
7: [2016/Aug/29|20:57:07] Listening port(s): default
8: [2016/Aug/29|20:57:07] --
9: [2016/Aug/29|20:57:07] System configuration:
10: [2016/Aug/29|20:57:07] Group aware processor detection:
11: [2016/Aug/29|20:57:07] Processor group 0
12: [2016/Aug/29|20:57:07] NUMA node 0, mask 0xFFF, used: true
13: [2016/Aug/29|20:57:07] --
14: [2016/Aug/29|20:57:07] Using system default affinity
15: [2016/Aug/29|20:57:07] Process id is 6032 (0x1790)
16: [2016/Aug/29|20:57:07] Executing "“C:\Program Files\Autodesk\3ds Max 2016\3dsmax.exe” -server C:\Windows\TEMP\vraydummy2016.max "
17: [2016/Aug/29|21:39:43] ========================== Ending session ==========================
I’am going nuts…
BB Jobs working
same max and vray versions
Thx
Phil
sloved it!
it was firewall related!
watch your ports! 20204
