needed a fun scene to test the ppt-rendering technique on, and well… this is what I came up with…
both the concrete animals and the ground uses Vray displacement, and all materials in the scene are more or less glossy.
lighting is made with a blue-ish gradient in the override environment slot, and a yellowish target direct light with vray area shadows…
DOF effect is also rendered… nothing except the black framing and the text has been added/changed in post.
I stopped the rendering after 1 hour… my system is kinda lame, its a p4 2.4 ghz without ht… 1 gig ram. so I thought this was really fast considering all the effects…
I wont be making any changes to this one, but crits n comments are always welcome anyways…
asango - yup… its the original resolution… but I did a bigger version yesterday. 1280 pixels wide (to be used as a windows backdrop).
let it render for about 3 hours and it looks pretty much the same as the one youve seen in terms of quality. but at that resolution you can see that the displacement map is a little streched here and there…
