Where can I find the Enscape material editor? I cannot find it.
? That is it.
Basically you assign a texture. (*) Then apply a bump map to it. Then apply a shine map or universal shine to it. You can’t see any of these changes in SU: only in the Enscape window.
(* you can apply a tint to it and fade it out at this stage or to tweak it)
You can tag the surface as a Special material (grass, water, foliage and clearcoat) and it drastically alter the way the texture appears in Enscape.
Thanks @Gadget_1 ! Does that help @susan_unsil_lee ? Please, let us know if you have any questions!
I mean, I don’t know how I can open the enscape material editor window.
If you don’t see the Enscape toolbar, R-click on a blank toolbar space and tic the “Enscape” and “Enscape capturing” toolbars on.
Each button has text if you hover the mouse over it, but the one you want is a cog in-front of a checkerboard pattern (between the tree and speaker)
I think you are running an old version:
(This is the preview, but if you download the latest stable version then you should see very similar icons.)
old version of sketchup? or enscape? I have sketchup pro 2019.
I downloaded latest sketchup now but I still have same tool bar without tree and checkboard icon.
Gadget! I download new Enscape version and I see the toolbar now.!!! Thank you so much!!! ^^ Thank you so much for your help!
