where is icon for Enscape after installed?
I am new here.
I had installed and can find the icon of .CustomAssetEditor.
But where is the app icon?? I cannot find it!!
Check that my colleagues PC, it seems that he created the shortcut by himself.
Can anyone advise the solution for me?
Hi @southerninterior , welcome to our Forum.
Since Enscape is a dedicated plugin for the following supported CAD solutions listed here Enscape will not have a dedicated app icon or shortcut to start - Instead you can execute and utilize Enscape via any of the mentioned CAD solutions, feel free to check out the following blog article to get you started and to clear up any confusion hopefully: https://blog.enscape3d.com/enscape-for-sketchup-get-started
The blog article above is mostly in regards to using SketchUp, but for example if you’re using Revit you will be able to access Enscape through a similar ribbon as well: https://learn.enscape3d.com/blog/knowledgebase/enable_enscape-revit/
I hope this helps. Please let me know in case anything still isn’t entirely clear.
