I’m having trouble with importing a duplicate rigged person from Anima to 3ds max. The problem is when the Anima person is imported into 3ds max, they have gray around their eye lids. This is because there is no opacity map for the eyelashes’ material so it renders out gray. When I tried importing the original rigged person, the material has the opacity map attached and the person renders just fine. I need to duplicate the person to add a variation to the shirt color. I’m doing this as a test for a work-related project. There will be a large amount of people in specific-colored shirts and it will take forever to manually add the missing opacity maps to each person depending on how many people I need to place. How do I get Anima to import the duplicate rigged person into 3dsmax with all the necessary maps? Any advice would be greatly appreciated!
Thank you for reporting this issue.
We confirm we can replicate the problem on our side too. It happens when the texture is edited, after the duplicate operation. At some point, when the edited textures are rebuilt, the material type is not properly reassigned and all of them appear as standard:
For the eyelashes to keep their opacity map, they need to be set as a Hair material type in Anima. This also means that not only the eyelashes are wrong, the other materials will not have an optimal setup either in 3dsMax until the bug is fixed.
We have tried to manually modify the material types, but the bug is also preventing that from happening, so it seems to be related to the UI at some level.
We have reported this to the Anima Dev team (AN-1467), the fix will be included in the next Anima update.
thank you for the update and I look forward to the next Anima software update.
