Hi I know v-ray should be directly linked to Sketchup sun position. but it is funny that. My vray rendering shows different sunlight angle than the sketchup. Is it the setting issue? can someone help??
Re: why the v-ray Sunlight has different angle than the sketchup?
It’s a known issue with the original release. To correct the vray’s sun position go to environment>GI>Sun>default and reapply it.
If you’ll change the SU’s sun position repeat this again.
P.s You can update (it’s free) to VRfSU to 1.05 in witch this problem has been fixed
