did someone notice install problem?
on my OS give this message during install
>SetupNew\setup.ccp (135)
PAPP:
PVENDOR:
PGUID:
@windows vista service pack 0 (6000) IE7.0.6000.16711
Re: windows vista 64 bit and 01.05.03
I don’t believe there are any conflicts with using Vista 64. As with all vista installs, you’ll have to be very careful to make sure that you’re running everything as an admin and that you can make the necessary changes (registry, program folders) that are needed to have a successful install. I believe that’s your main issue.
humbly offer my apologies …
I re-file and everything goes perfectly …
probably has lost the pieces to move between the dense mesh network!
ciao ciao
davide - PDT
