Hey!
I need a help with this one, I have not had this problem before. It seems that the rendering machine is putting in the sky reflection where it should not be.
Is there any solution to fix this?
I had to turn of the main glass facade, because it was bleeding through the walls with a sky reflection. The photo from a video where the main glass facade is turned off, But still a little bleed.
I made a test model with materials that are inbuild in revit. and basic walls. Still the same problem so it is not our model its the software.
Thank you
Hey @Thorsteinn , thanks a lot for your post.
This may very well be a normal behavior. Still, could you please make sure you’re running our latest release, just in case you’re not on 2.5 already - the reason, we always strive to improve our real-time reflections, and you may already get a better output if you’re currently using an older version. In case you’re already on our latest release:
We generally adjust the complexity of our reflections (among other factors) corresponding to the layers of glass. Real-time reflections always involve finding a mix between performance and true-to-life output, and if we were to render reflections correctly, when looking through, for example, three sheets of glas, then Enscape would become unusable pretty quickly due to the performance which would be required.
Furthermore, you can check out our dedicated FAQ article regarding reflections here which explains in further detail why some part of your project is not being displayed in reflections, and more about how we select what is being displayed (in full detail or reduced detail) and what not.
You can also gladly send me the project itself for me to check out, since it’s a bit hard to see if everything is normal here by just looking at the pictures.
Thanks a lot in advance for your consideration!
Thank you for the reply Demian.
I am not demanding a 100% correct reflection on objects
I can imagine the 3 glass walls are complicated for the render machine but in these cases having an option to turn off reflection would come in useful. After all even tough the reflection is a nice future and all it´s better to display the work with out glitching reflections in a video.
Turning off all reflection for all glass material in Revit works, turning off material reflection for only the interior glass walls does not work. still bleed. I would like to keep the reflection on the glass facade but like I mentioned above it would be handy to be able to just check a box in the settings on or off.
I am not 100% sure but I think I did not have this problem in the older versions.
Where can I send you my sample for you to look into this?
On a side note:
I really like what you guys have done with the program, keep up the good work.
Best regards
Thorsteinn
@Thorsteinn , thank you for your response.
This behavior should’ve also occurred in previous versions of Enscape, but I’ll gladly check that out as well once I have the sample file. You can upload the sample file to wetransfer.com for example, and share the download link with me via PM.
Further, I’ll file a dedicated feature request to allow you to simply turn on and off reflections in Enscape. I appreciate your feedback.
Thanks a lot in advance!
I have a similar problem except this is happening on an interior space. There is a curtain wall 40 feet down the hallway but that should not get picked up. It looks like there was a similar thread in April of 2017. Turning off reflectivity in the Revit material does not seem to change anything.
I am on version 2.4.xxx. I have requested the new version (2.5.1.9-xxx) to be installed by my IT dept hoping this will fix it.
Is there any other suggestions?
Newest version loaded and reflection is still present
I can confirm that I am also seeing sky reflection on glass that is facing a solid wall.
Please be aware, that when you set the Rendering Quality to Draft in the Enscape Settings, reflections will be highly simplified - thus they only reflect the sky but not geometry behind or around it. Setting the Rendering Quality to Medium or higher allows for more complex reflections.
@Dsperry , it’s a bit hard to figure out what’s going on here, is there any chance you could send me the project which is seen in the screenshot so that I can have a look at it? Generally, if anyone experiences reflections where there should be none, kindly send me the project with a short description accordingly. You can upload it to Wetransfer for example and send me the download link via PM.
Hi again Demian
Did you get the link I send you because the model I send you has not been downloaded.
Hmm, it looks like your files haven’t been downloaded yet, and this transfer will be deleted on 24 April, 2019.
This problem is not because of “draft” its the same on high and ultra.
I had a look at the project, thanks again for sending it over!
I’m afraid, there is really not much we can do right now - I was also able to reproduce this behavior in older versions of Enscape. Still, your wish to have an on/off option for reflections in general will definitely be forwarded to our developers.
