If you have not yet updated your License Server to version 6.1 or above and are unable to access your license please follow these simple instructions HERE.
If you already tried this and are still unable to access your Chaos products, please contact Chaos Support.
Here you go. I don't have time to go through and screen cap all the various map tilings etc. so you'll just have to play around and figure it out. Or grab a Max demo
As I stated, I have recreated your Ice in Viz. It is not as good as yours, but that is probably due to the output maps. I am not sure how you have them set.
The original bitmaps are not included in this zip, just the MAT file.
I'll have to take your word for it - I don't use Viz The Output maps were set to 1 or .98, so you can reproduce those values by full or 98% white colour, so if you just have white in those Output slot areas you'll be very close.
It could just be the lighting and background that are making the difference.
We are moving to 3ds in July, so I should be able to see the difference then.
