SOLUTION for Vraylight skylight portal problem...
  • #31
    and what are your system units ?
    Natty
    http://www.rendertime.co.uk
    • #32
      I get the same result like cocolas...!
      I've tested around with the units and when you open the scene and adopt the units from it, it changes your settings completely!
      best regards
      themaxxer
      Pixelschmiede GmbH
      www.pixelschmiede.ch
      • #33
        best regards
        themaxxer
        yeah...it changes the scale of everything around........but I haven't looked at the system units (don't have max in front of me now).....I'll have to give it a try.....
        paul.
        • #34
          Just wondering if anyone got the scene to render out correctly/bright?
          I tried it and it was dark, all lights were on and reset the irr map,
          Nice scene Matt
          Tom
          Accept that some days you are the pigeon, and some days you are the statue.
          • #35
            hi guy's
            just whent through the file and the lights are set to 0.0 for the diffuse multiplier. = dark render
            turn it to 1 and everything is fine.
            why its set to 0.0 i dont know..
            Regards
            Natty
            • #36
              Hiya guys, this is what i got after playing a bit with the photons, i think it has sharper shadows and its not so aggresive in the light openings, you can still look at the detail on them....
              Also i feel that the light needed a little turn down on the yellow side, but i didnt touched the blue skylight. Ill try and post some scene with materials if i got time!! Cya .......
              Best Regards.
              Jorge Zamudio.
              • #37
                Hi, guys... I use mm/mm render time photon map - 2 min
                • #38
                  2 mins - aa ...
                  Natty
                  • #39
                    hi triar
                    hey, great light in the scene... did you change anything in the scene from zero one?
                    thanks in advance
                    themaxxer
                    I've noticed the diffuse multiplier of 0.0 but I thought it is right.
                    Pixelschmiede GmbH
                    • #40
                      2 mins - aa ...
                      AA has no effect on a photon cal'c ...
                      Eric Boer
                      Dev
                      • #41
                        yeah my mistake .... didnt look at the rendertime ...and i thought that was the rendertime.... oops
                        Natty
                        • #42
                          to the maxxer
                          2 themaxxer
                          I think the last solutions from triar has only a gamma output in max with a value about 1.3/1.8 applied because the colors are desaturate and the image aspect when gamma output is applied is this
                          Maybe I'm wrong
                          Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
                          https://www.facebook.com/essetreddi..../photos_albums
                          • #43
                            [/quote]hi triar
                            thanks in advance
                            themaxxer
                            [/quote]
                            Sorry, i use mm/mm , but height room in my file 1400mm --oops...
                            i change settings in matt scenes very cool, 1. rescale World scale in max 6 & decrease sbd - tweak VRlights& sbd in propertis rollout
                            ---> file in max6::http://triar.dezigner.ru/int_triar-max6.zip
                            • #44
                              hey Zero One 010110,
                              I really like your lighting solution.....if you could post the scene, that would be great.
                              thanks for the scene, triar, as well
                              paul.
                              • #45
                                for those who have dark solution with my file...it's due to units system i think
                                here is a generic units version :
                                http://membres.lycos.fr/xxmattxx/vray/int-gen-units.max
                                tell me if you have the same result:
