I would lower the reflection and glosiness of the walls a bit. What are your settings?
David White Lane
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Love the kitchen shot! How does the render time compare to your previous job settings? As in, are the new default settings any better/faster than your previous settings on past jobs? I would personally reduce the brightness of the pendants over the island so you can see more of their shape. I usually resort to a self-illumination material with a fall-off for the light output so you can see the contours of the surface better. That's probably cheating though.Work:
Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
V-Ray Benchmark: CPU 00:52 | GPU 00:32
Home:
AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
V-Ray Benchmark: CPU 00:47 | GPU 00:34
https://pcpartpicker.com/list/kXKcxG
I don't recall the previous render times, but this time it is ridiculously high.Originally posted by particlerealities View PostLove the kitchen shot! How does the render time compare to your previous job settings? As in, are the new default settings any better/faster than your previous settings on past jobs? I would personally reduce the brightness of the pendants over the island so you can see more of their shape. I usually resort to a self-illumination material with a fall-off for the light output so you can see the contours of the surface better. That's probably cheating though.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Let me wrap it up and post it, thanks!Originally posted by 3LP View PostWana try this in GPU?
If so, send me the scene and I'll try it out
StanBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by flino2004 View Postwhen I use reflections on the walls I apply vrayoverride material... with I simplified version of the base material for reflection.(without bump) ..... it works great if you have corners and produce a lot less noiseBobby Parker
phone: 2188206812
- Windows 11 Pro
phone: 2188206812
- Windows 11 Pro
Originally posted by flino2004 View Postyes, the material is a diffuse color without reflection of course and bump.... so when they reflect themselves only pick the flat diffuse colorBobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
