Disney released some interesting assets. I found very nice cloud render there. How can we do same shading with phx ?
  • Disney released some interesting assets. I found very nice cloud render there. How can we do same shading with phx ?
    https://www.disneyanimation.com/technology/datasets
    CG Artist
    For clouds you better switch the Scattering mode to Ray-Traced, this would be the most important bit to the shading.
    Here is a clouds sim and render tutorial with some settings: https://docs.chaosgroup.com/display/.../Static+Clouds
      I can't find a way to even mimic that scattering. Only some geo mode + vray volume scatter material with several layers
      CG Artist
        How do your results look right now?
          Like this using env fog. Kinda surprised
          http://joxi.ru/brRQYZpSJaW0dA
          Phx looks like a smoke. Hyperion uses some new techniques (IMHO).
          http://joxi.ru/nAyb9KMhYxLZBr
          Fastss2
          http://joxi.ru/YmE9NM0t04KgQm
          P.S. Lightcache ate all my 64gb for 2gb vdb. Kewl
          CG Artist
            Seems like your render step for the fog is very very large.
            For Phoenix, wouldn't it look better with less opacity? Right now it looks almost solid.
            Do you mean the Phoenix light cache or the V-Ray light cache?
              phx lightcache
              less opacity - still like just s smoke. only fastsss2 looks close.
              CG Artist
                Here is my go at the cloud. You can check my settings in the attached scene.
                Rendered with Phoenix and V-Ray Next GPU.
                Georgi Zhekov
                Phoenix Product Manager
                Chaos
                  serious <3
                  Lele
                  emanuele.lecchi@chaos.com
                  Disclaimer:
                    Yeah. Still looks like smoke. This is different type of cloud (IMHO). And it now can't be rendered with phx, only with fastsss2.
                    CG Artist
                      Starting off with Georgi's scene, I got this:
Name:	cloud phoenix 3.11.jpg
                      This is with a build from yesterday, here is the scene as well: Clouds_scattering_Max2016.zip
                      The highlights for this kind of shading include:
                      - Use Probabilistic Shading from Phoenix's Atmosphere - 8 direct samples, 1 GI sample.
                      - BF/LC GI, progressive sampler, Ray bundle size = 8 for more responsiveness.
                      - Phoenix light cache off - it's better to turn it off with progressive.
                      - scattering = Ray-traced
                      - smoke color = pure white - this way light scatters the most
                      - simple smoke opacity = 0,13 - the lower this is, the longer distance the light rays will travel before scattering, but if it's too low, the smoke would lose its shade detail.
                      I think mostly everything else is using defaults.
                      Currently there is no scattering phase function in the Phoenix shader, which would allow you to get the dark edges of the cloud.
                      Cheers!
                        Indeed, the Mitsuba file has a strong (0.83 if memory serves me well) forward scatter of the HG type.
                        Lele
                        Disclaimer:
