Ship in Ocean
  • #31
    Huh, thanks for the info and the scenes! Will check what's needed to adjust in these and get back to you...
    • #32
      Thank you Svetlin!
      As a side note, I checked quickly the other quick settings (fire, explosion, waterfall...) and everything seems to behave normally.
      www.mirage-cg.com
      • #33
        another test in Maya2017. Simple cube of 1 meter with quick ocean preset...
        https://vimeo.com/195271813
        www.mirage-cg.com
        • #34
          Any news Svetlin?
          Here is a cube of 1cm. I would say that it looks rather like a cube of 1m.
          https://vimeo.com/195465852
          www.mirage-cg.com
          • #35
            Wow, this looks like a particular meteor the dinosaurs would dislike. I hope we'll be on this in a couple of days - we're under a small avalanche of stuff... Will keep you posted.
            • #36
              here is another Meteor with a 10cm cube. Same setup as before...
              www.mirage-cg.com
              • #37
                Btw, with such a fast moving obstacle, you can expect so much foam and splash - if the preset is working fine, the cube should behave like it's as big as a ship, so it should be moving more slowly
                • #38
                  well, there are ships and ships..... if I do a 1cm cube, it should be a microscopic ship, if I do a 10cm ship, it should be a scale model (rather tiny scale model) ship; if I do a 100cm cube it can be a nice scale model ship, if I do a 400cm cube it should be a small boat.... if.... etc....
                  When I read you, sometimes I have the feeling that it does "just a ship", but there is a difference between a small motor boat and a Tanker
                  www.mirage-cg.com
                  • #39
                    This one looks good! 100cm radius Torus with 30cm section Radius
                    https://vimeo.com/195620998
                    https://vimeo.com/195620965
                    www.mirage-cg.com
                    • #40
                      Now things start to look slowly better. I used the scene from the Torus and replaced with the boat. The boat is 4 times too small and I had to make the grid bigger. The good thing is that the boat really looks too small! I will make another test with a boat at 1/2 scale.
                      I wonder why we have the step showcased in the screenshot.
                      https://vimeo.com/195779349
                      https://vimeo.com/195779293
                      www.mirage-cg.com
                      • #41
                        I'm having trouble figuring out how to connect my fluid container to my boat in Maya so that it moves in space with the boat geo. Whats your method?
                        • #42
                          Simply group the boat and the Phoenix simulator. Animate the group. At least that's what I do...
                          www.mirage-cg.com
                          • #43
                            Thank you so much!
                            • #44
                              here the result with boat at half size with the ocean from the torus scene. Looks like something better. I'm doing a longer simulation to see how it goes.
                              https://vimeo.com/196145835
                              www.mirage-cg.com
                              • #45
                                Now, this starts slowly to look like something. It's still based on the "Torus ocean". I'm curious to see what happens if I delete the ocean and recreate one based on the same boat. I will try....
                                https://vimeo.com/196838566
                                www.mirage-cg.com
