Originally posted by waaazoo
View Post
Ship in Ocean
Originally posted by a0121536 View PostThat's right - the preset creates a bigger grid so the ocean can move around it. Maybe it would be a better idea to have the preset attach the grid to the object instead.
Yup, the thing is that this Quick Setup can be used both to have a ship travelling along the ocean surface, as well as to have a geometry splash into the ocean or fly out if it, so it's made bigger in all direction in order to accommodate such cases. Maybe we could have a separate ship preset and another splash tank preset which would make this easier.Svetlin Nikolov, Ex Phoenix team lead
Originally posted by a0121536 View PostYup, the thing is that this Quick Setup can be used both to have a ship travelling along the ocean surface, as well as to have a geometry splash into the ocean or fly out if it, so it's made bigger in all direction in order to accommodate such cases. Maybe we could have a separate ship preset and another splash tank preset which would make this easier.
As said previously, I did the test using the scene with the ocean scene created with the torus. I delete all phoenix nodes, clean up, and recreate an ocean based on the ship.
As you see in first screenshot, I'm using centimeters and my boat is now 45meters long (half size of the real boat).
In second screenshot you see that preset creates a huge grid around the boat. I added the grid settings for you to see what it does.
In third screenshot you can see the start of simulation. BTW, there is again the bug of ocean mesh preview that floats way above everything. You need to save the scene WITH mesh preview ON and reload, to have the mesh preview in correct altitude.
In the Video, you see the result (bottom of page). Either I'm doing something definitely wrong, or the preset doesn't work as it should.... (it should at least create something like on this video https://vimeo.com/196838566)
https://vimeo.com/198816471
Yup, exactly - the bigger grid is created currently in order to be able to use the ocean preset as either a ship scene, or a splash volume. In the future, we should split the preset in two for these two tasks and I promise the ship preset will be smallerYou'll have to shrink the grid manually until then. Our QAs are trying to reproduce the ocean level preview bug right now...
I would like to renew my question posted on an other topic:
For simulation, would it be better for a CPU to have less cores but higher speed (4 x 4.5Ghz), or more cores at lower speed (10 x 2.3Ghz), or does it not affect the simulation render speed?
Of course in my example I have 18Ghz versus 23Ghz, Lol, but I think you understood the principle of the question... (let's say 8 x 2.3Ghz)
Simulation is really long. Currently I'm simulating on a i7-3930K slightly OC at 4.3Ghz
Well, my x79 setup at home (3930k OC at 4ghz) by far outperforms the dual Xeons setup (6 core 2.1ghz per CPU). I'm waiting on the greenlight to build a new machine at work and I am going down the i7 6/8 core route with the fastest memory available.
My x79 setup and the dual setup uses DDR3 and I think the memory in my home machine is a lot faster than the Xeon setup but there is also no communication between 2 CPU's needed.Adam Trowers
Originally posted by flipbook View PostWell, my x79 setup at home (3930k OC at 4ghz) by far outperforms the dual Xeons setup (6 core 2.1ghz per CPU). I'm waiting on the greenlight to build a new machine at work and I am going down the i7 6/8 core route with the fastest memory available.
Thanks a lot Svetlin and Paul. great to know. I will go and search for a new Rig
I went back to an old scene done in 2014 as I couldn't get any satisfying setting for my ocean.
He is the result so far with some little tweaks. Maya settings are in cm as you can see in the attachment.
I kind of like what happens in the front, but then, the foam doesn't extend enough to the sides. It would be nice to have splashes/foam on the wakes on each side.
I have probably to lower le rising speed of foam as it seems to float around in the air.
At stern, it looks quite ok for a start (no propellers for now).
Also, there is a ton of foam under the water line. Is it possible to reduce this, and how?
Attached are the complete settings.
Help would be appreciated. I'm still quite confused with a lot of settings.
It's difficult to know which parameters are affected by the size settings (it seems that in Max you have always cm or m next to the numbers which would help).
I watched several times the boat tutorial, and looked everywhere on the forum, but....still regularly confused.
It's quite long to simulate, so it's impossible to test every parameter one by one. To do testing, I used a smaller grid only on the bow of the boat, but it was still long
bow:
https://vimeo.com/201827048
underwater:
https://vimeo.com/201827163
stern:
https://vimeo.com/201833509
from the side:
https://vimeo.com/201843286
Hey,
You should increase the falling speed instead, so that the foam that is in the air can fall down to the water surface faster. If there is a lot of foam underwater, then it seems like you need to increase the rising speed as well.
From the stern video, it looks like you should also increase the Outside life, but first check if you have the Age of the Foam exported. Since your half life is at 1 (second), and you have so much foam, it might be related to a missing Age channel export for the Foam...
However, I see you are not using FLIP advection - is this on purpose?
Cheers!Svetlin Nikolov, Ex Phoenix team lead
Cheers!
Age is not exported for anything. Should I export it for the foam and the splashes?
Thanks for the help! I can't wait to have something looking good
