Ship in Ocean
  • Thanks Svetlin!
    Based on my Balls scenes, I added the Ship.
    I made 3 simulations over night, and here is the one that looks best. I'm simming again with some different settings.
    Changed SPF from 2 to 4, changed quality from 30 to 50 and added 0.1 surface tension hoping to get less "holes" in the water at bow.
    Please let me know if you have some other comments.
    https://vimeo.com/203272739
    www.mirage-cg.com
    • Huh, is the hull a single solid object? Looks like the liquid at the bow penetrates it a bit and then comes back out. Also, how many voxels do you have in the grid?
      • Originally posted by a0121536 View Post
        yes, object is perfectly closed (maybe too low polygon?). I have 18 million cells in the grid.
        This is seen from the inside looking at bow. It penetrates a little.
        www.mirage-cg.com
        • Hi,
          Should I raise the splash drag? it seems the splash particles are floating in the air...
          https://vimeo.com/203423072
          www.mirage-cg.com
          • I had to remove the splash drag obviously.
            Looks quite nice here
            https://vimeo.com/203438658
            www.mirage-cg.com
            • Looking good indeed!
              • Now this starts to look sweet.
                I need to keep alive the foam a little longer.
                https://vimeo.com/203781690
                www.mirage-cg.com
                • Niiiice Are these foam or splash particles flying from the wave crests?
                    I'll give you a visual answer
                    Splashes:
                    https://vimeo.com/203808437
                    Foam:
                    https://vimeo.com/203808383
                    www.mirage-cg.com
                    • Resim seems to create foam on Grid borders (frame 27 here). Let's see what happens around frame 100 or later...
                      www.mirage-cg.com
                      • Hi,
                        We are aware of the this resimulation issue and working on the fix for it. Will post here when we have any updates.
                        Tashko Zashev | chaos.com
                        • too bad for the resimulation... I'm looking forward to test an update.
                          here is a new simulation. Less cells, but bigger Half Life. It's getting interesting.
                          https://vimeo.com/203999273
                          https://vimeo.com/203999203
                          https://vimeo.com/203999142
                          https://vimeo.com/204010413
                          www.mirage-cg.com
                          • Getting nice results I gave up on my boat sim, work on real projects took over
                            Adam Trowers
                            • What I really miss in phx flip core, is that I failed to produce that kind of rolling water over the water effect, that is easily achievable in f.e. naiad, houdini or even bifrost. If someone can prove me wrong - that would be really great.
                              https://www.shutterstock.com/ru/vide...l/2590949:0/gg
                              I just can't seem to trust myself
                              So what chance does that leave, for anyone else?
                              CG Artist
                              • I know what you mean, did seem to get that effect with a lot lower resolution with Naiad but I'm sure it can be achieved with Phoenix. It is more the rolling of the foam/splash over the surface I suspect. Shall give it a try soon!
                                Adam Trowers
