V-ray Fur, Fur map modifier, Fur Material -- Which is the one to use?
  • V-ray Fur, Fur map modifier, Fur Material -- Which is the one to use?
    As the title suggests, I'm getting a little lost on what the difference between them all is and when to use what.
    I want to create some nice realistic carpet and have been using Vray Fur which seems to be giving me decent results. My question is: How can I map a reflection map for some bright/dull spots like somebody has walked on it to it to make it a little more realistic? Is it just a matter of plugging say a noise map modifier into the reflection slot of the material assigned? Will that map to the whole carpet area or each individual strand though?... that's where I'm getting a little confused.
    Maybe soething like this?
    Max file: dywan na forum.zip
      More like this
        But I mainly want to know what all the differences are between all these different vray fur type materials/
          Max file: [ATTACH]n973362[/ATTACH]
          Sorry, don't want to hijacking this thread but could you, please, give a max2015 version ? It would be nice ! if you don't mind of course
          I had to do a carpet a few weeks ago and I finally used vrayfur with some maps, noise, gradiant in different way but I wasn't totally satisfy at the end
          Your carpet is really interesting !
          Thanks in advance
          (Sorry for my bad english)
            Sure, here is: dywan na forum 2015.zip
              Sure, here is: [ATTACH]n974375[/ATTACH]
              Thank you very much Mnietek2707 !!!!
              very informative for me !!
              I did not think the squares were made from the base geometry of the rug ... I was thinking more about a mix and/or a composite with procedural and/or bitmap in the Bend / Initial direction slot , and so on.
              In fact, it's simpler but much more efficient!
              I'm going to play my way based on your example, thank you again for your sharing
