Just to double check... Vantage doesn't support displacement, correct? This is a deal breaker for 90% of my exteriors. I am assuming, once it does, we'll be a lot closer to GPU render speeds.
Displacement
Displacement
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
I usualy model everything, from siding to asphalt shingles. However, I am working on a house with wood cedar shakes, which I can't model, so I need displacment. Maybe next time/Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by suzanne_doherty View PostYou can use standard Displacement modifier, so maybe just use this for close-ups and bump / normal for distant objects?
Distant objects I use only normals and bumps because it is a waste of resources...
- Likes 2
I tried modeling cedar shakes, but I couldn't pull it off. I can invest more time, when I have some time.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I was going to put this one through Vanatge, but I would lose my roof detail.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
So, the secrete is using MAX's displacement?Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostSo, the secrete is using MAX's displacement?
May I ask you, with your permission, of course, you can send me the house you have posted (complete project with textures) and to try to apply the roof some my "magic" displacement formulas that I have experienced in the past months.
The sad part is that the displace function will take a very long time from now on to be implemented natively in Vantage and so far I have managed to come very close to true v-ray displacement in Vantage, with my little formula
I'll simplify it and post when I get a chance. Thank you!Bobby Parker
phone: 2188206812
- Windows 11 Pro
