Displacement
  • Displacement
    Just to double check... Vantage doesn't support displacement, correct? This is a deal breaker for 90% of my exteriors. I am assuming, once it does, we'll be a lot closer to GPU render speeds.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    You are correct - Vantage doesn't currently support displacement.
    That said, it is something the team is working on, and we hope to support displacement in the not-too-distant future.
    Stay tuned!
    - Phil
    VP Product Management, Chaos Group
      I usualy model everything, from siding to asphalt shingles. However, I am working on a house with wood cedar shakes, which I can't model, so I need displacment. Maybe next time/
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Why can't you model them Bobby, out of interest? I recently did a thing with cedar shingles and they seem simple enough, so just curious if yours are some particlar sort.
          I have managed to simulate displacement 99% in Vantage but with very high costs of performance (I mean in 3DS Max, lots of RAM usage, over 100 GB). Click image for larger version
          My secret recipe works
            You can use standard Displacement modifier, so maybe just use this for close-ups and bump / normal for distant objects?
            Dean Punchard > Head of CGI at HUB
              I preferably use displace modifier with two stacks of turbo smooth and in the vray mtl I use normal + bump with at least 30% intensity.
              Distant objects I use only normals and bumps because it is a waste of resources...
                I tried modeling cedar shakes, but I couldn't pull it off. I can invest more time, when I have some time.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Show me a reference and I'll see what I can do in my (at present) free time
                    I was going to put this one through Vanatge, but I would lose my roof detail. Click image for larger version
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Displacement (Turbosmooth x 7 + Displace + Another Turbosmooth x 1) + Normals and Bumps at 100% (Ground and tires)
                      A true beauty, isn't it?
Name:	Screen Shot 10-18-23 at 12.43 AM 001.png
ID:	1193355 Click image for larger version
Name:	Screen Shot 10-18-23 at 12.43 AM.png
                        So, the secrete is using MAX's displacement?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Yep. Good ol' Max Displacement and Turbosmooth
                          May I ask you, with your permission, of course, you can send me the house you have posted (complete project with textures) and to try to apply the roof some my "magic" displacement formulas that I have experienced in the past months.
                          The sad part is that the displace function will take a very long time from now on to be implemented natively in Vantage and so far I have managed to come very close to true v-ray displacement in Vantage, with my little formula
                            I'll simplify it and post when I get a chance. Thank you!
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              Another fine example with simulated displacement in Vantage
