Vantage 2.2 Crash
  • #31
    Originally posted by Alexander.Atanasov View Post
    Hi lin_mobai,
    Can you send us the debug log file from %AppData%\Chaos\Vantage so we can investigate? You can also checked this thread here as it might be similar to yours:https://forums.chaos.com/forum/chaos...-start-anymore
    Alexander
    I tried his method of modifying the ini file into bak, but it still didn't work.
    • #32
      Please send the DMP file from your %TEMP% folder (the file mentioned in the error popup).
      Nikola Goranov
      Chaos Developer
      • #33
        Originally posted by npg View Post
        请从您的 %TEMP% 文件夹发送 DMP 文件(错误弹出窗口中提到的文件)。
        It says I don’t have permission to upload files​
        • #34
          Ah, strange, I think other users were able to upload such files. Sorry about that. Can you use a file sharing service and post a link to the file?
          Nikola Goranov
          Chaos Developer
          • #35
            https://drive.google.com/file/d/1kAQ...usp=drive_link
            • #36
              Thanks, I see that the program crashed in vrclient_x64.dll which is part of SteamVR. We will investigate. Does turning off Steam help?
              Nikola Goranov
              Chaos Developer
              • #37
                See this post. It is probably the same issue you are having: https://forums.chaos.com/forum/chaos...85#post1211485
                Nikola Goranov
                Chaos Developer
                • #38
                  Still crashes after exiting steam
