Problem with molotow-cocktail - liquid through wall
  • #46
    I think you can just restart your sim with timescale animation. That should fix the problem, if no other soluions are found.
    CG Artist
    • #47
      the anim index uses also blending
      VRScans developer
      • #48
        Hi Paul.
        Thank you for answering!
        Yes, I also thought of that - that may be a solution, but it would be very, very uncomfortable and time-consuming - I would have to simulate A LOT of unecessary frames - each time I have to retime.
        Testing this solution would cost days...
        That would definitely endanger my deadline!
        • #49
          btw, what blending method you are using?
          VRScans developer
          • #50
            Both...
            ...with the same result...
            • #51
              Now I´m checking if only the moving simulators are affected...
              • #52
                Maybe it has to do with the adaptive grid?
                • #53
                  Yeah, that seems to be the problem...
                  ...I think I can reproduce now...
                  • #54
                    omg, isn't the frame blending not forbidden with adaptive grid?!
                    VRScans developer
                    • #55
                      Isn´t it not forbidden - therefore allowed? Or is it forbidden? I do not find anything about that in the documentation...
                      Does it mean that if I want to use Playspeed / Anim index - I cannot use the adaptive grid?
                      That would destroy my whole setup and I have to begin from scratch...
                      • #56
                        it should be forbidden, no way to blend frames with different size.
                        VRScans developer
                        • #57
                          Shhhh.........
                          • #58
                            That´s really evil...
                            Alarm...
                            Okay, two ways to solve this:
                            1. Make everything without adaptive grid
                            2. Use adaptive grid but animate the speed with time scale in dynamics
                            Second solution will not work, because I have nearly 1000 Objects influencing the sims - and therefore I would have to retime them all at once - which is not managable - at least with max 2012, 2013 has some new retiming-features, but I cannot change the whole pipeline 2 weeks before deadline...
                            Please, add this information to the documentation - that might have saved me from running into this trap.
                            • #59
                              Or better a warning-popup whenever activating the adaptive grid...
                              ...like with the shellac-mode in the vray-blend material...
                              • #60
                                yes,some notification is really missed. or we can try to improve the blending to work with adaptive grid
                                VRScans developer
