remove splash on grid boundaries
we don't have vray3 yet, will it suffice to follow the wibu update routine discussed here ? http://forums.chaosgroup.com/showthr...license+server
You don't need V-Ray 3.0 in order to run the latest nightlies of Phoenix FD.
You have to run Phoenix FD license server for the corresponding version.
Go to Start - All Programs - Chaos Group - Phoenix FD Adv for 3ds Max 2014 for x64 (in your case) - Licensing - Launch Phoenix FD license server.Tsvetan Milanov
Chaos
the splash birth is modified. the most important change is the birth on thin layer liquid over a geometry, the official release produces many splash in such situation, the nightly build does not. i suggested to use the nightly build because i thought exactly this is the problem, isn't it?
however the splash produces by the free flying liquid are also changed, in order to bring the simulation and resimulation results closer.______________________________________________
VRScans developer
hmm not sure, the geometry splashing was ok, i was more concerned about the grid border splashing.
splash birth is not a problem i can just crank that up, but with the nightly the threshold seem off, even at zero or very low threshold there's still no splashing unless there is huge amounts of turbulence involved.
i wonder if this is what caused your phx mapper scene not to produce any splashes here either
that surprises me. there is one trick that may help to adjust the splash, select the simulator, open the listener window, and type $.zmr=6
this will export the splash birth potential in the smoke channel. you can measure the values using the preview ranges, set the upper range to 1 and move the lower range in order to see at which value given cell changes its visibility.
this trick may be used not only for adjustment, but in the rendering as well, this field may be rendered as white smoke and this will make the liquid to look milky.
so, i have no clear image for you situation, would be good if you post here the view of the liquid in the viewport (as mesh with diffuse material)______________________________________________
VRScans developer
