melting geometry
  • melting geometry
    I'm looking for ideas to accomplish the following using Phoenix FD:
    --a static model starts to melt in various places controlled by noise or some other means
    --the melting areas deflect off the still solid parts of the model
    --uv's are maintained so any texture maps stretch with the fluid
    --ultimately the entire object melts as the noise (or other) expands completely
    Could all this be done with Phoenix perhaps? Thanks in advance!
    unfortunately the mapped viscosity is still not supported, so this should be a hard task.
    VRScans developer
      hi Ivaylo,
      thanks for the response. i see. i'm also open to suggestions for cheats where features aren't available.
        can you point a reference video that shows approximately what you pursuing ?
        VRScans developer
          https://vimeo.com/74110954 ?
          Adam Trowers
            without animated viscosity, the only way is animated geometry and hard manual work.
            VRScans developer
              thanks so much flipbook for posting the sample - yep, that's pretty much it. roger that Ivaylo regarding 'animated geometry, manual' method. What would be that method you are describing? I'm interested to hear about it. (If I have to utilize a little brute force - if it gets the shots done, that would be fine.)
                manual method means to design the mesh for every frame
                VRScans developer
                  i see. thanks very much. i may also try it with particles taking over the mesh
                    in the PHXsource, is the discharge map functioning?
                      It should be, are you trying to modulate the particle discharge with it?
                        i'm trying to only emit over parts of the geo using a noise map. i'm shutting off the discharge on frame 2. when the map is active and pointed to the noise map i get no emission of fluid
                          it it possible the discharge map for phx liquid source isn't working? also when using phxmapper helper i get a crash - even when excluded. max2012, build 25910
                            Affirmative, we'll check it.
                              the discharge map is affecting the amount of the liquid, if you use drag particle (why you need them?) you have to map the particle birth value, not the discharge
                              VRScans developer
