New V-Ray feature revealed
  • There is a chance that the next internal build runs on Max 6.0 ?
    Yes.
    • ....and mabye with DR ? i miss that feature a lot
      • Originally posted by egz
        You should get your TD to check the download page on his account, since they might just make the build available there without emailing you back immediately. I imagine they must be getting a lot of requests.
        He's checked it and its still not available, how long does it take to get. I am trying to evalute whether to you Vray for this project or start looking at Final Render, I need to create a pipeline.
        • How about version for Max 4.x?
          Mare
          • what is a vray mesh?
            • Hi glow
              i think a Vray mesh is a featuer you get from the upcoming version of vray used for very big scenes that max usualy wouldnt handle anymore.
              with the new "unlimeted geometry" features you still have the geometry limits making big scenes inside max.
              the vraymesh seems to be a plugin coming with vray soon to solve these maxproblems with some sort of proxy objects, to stich such big scenes together
              greetings
              Tom
              • Originally posted by gl0w
                If ever you have use ribArchieve or delayRibArchive in renderman, this is a very similar concept.
                • so you put a low res tree in your scene and have it exchanged for a high res version from another file at render time?
                  • Internal Build
                    Excuse me if this is off topic -
                    I've just installed the internal build and two minutes after -
                    am having fast exits whenever I start to move a vrayfur
                    or vrayplane. Is this a bug?
                    I understand that the internal is BETA and prone to
                    weird behavior. Just wondering if this is a known bug or
                    what...
                    I would probably switch back to "n" until I get this sorted out ...
                    Regards,
                    Roy
                    vertex wrangler
                    • Ron, the whole idea of the internal build is to get as much feedback as possible; so bug reports and comments are welcome if you send them to vray@chaosgroup.com. Which display driver are you using in Max? Does the bug still happen with the software z-buffer driver?
                      • Hi Vlado,
                        I'd like to know if there is anything I should do to have access to the intermal build.
                        Fermí Bertran
                        • I belive I´m registered. Can I try it allso?
                          /Daniel
                          Daniel Westlund
                          • Originally posted by vlado
                            Apologies Vlado, - I was actually wondering where to post seeing
                            we haven' t got no internal build forum yet. To answer your question,
                            Moving the Vrayplane or VrayFur while using OPENGL will cause MAX
                            to exit. It does not happen at Software-ZBuffer/Direct3D mode.
                            Regards,
                            ROy
                            vertex wrangler
                            • Roy: I'm unable to duplicate that crash here. Moving the VRay fur or plane works fine.
                              Torgeir Holm | www.netronfilm.com
                              • Which card and drivers are you using?
                                (Where did the edit button go?)
