... i thought i´d be the only one with that viewport experience
3dsmax2014 FYI
bit offtopic, but to those of you having the weird misaligned top/front/side views, are you using cameras in your scene? i found that if you start switching between the camera view and other views, within a very short time they'll get misaligned, and youll have to restart max to fix it (until it comes back again when you use cameras)
ive actually submitted this to Autodesk through their bug report system, and subsequently got a response from them saying that they were able to reproduce the issue following my instructions and that they will fix it in the first service pack...so fingers crossed...
With regard to the misaligned view, I have found (if you have your viewcube active) that if, for instance your front view is screwed up, you can align the viewcube to Front, and click it a couple of times, then your front view will become aligned again.
Regarding the new vector map. Quick test on a scene using DR, 2k illustrator file masking some small details on a refraction-heavy object, the rendertime went from 8 seconds to 107 seconds. Switched the mask to a jpg and everything's fine again.TD at http://brinkhelsinki.fi
3ds Max 2013 with VRay 2.30.01.
Win 7, Intel Xeon X5675, Nvidia Quadro 5000, 48 gb ram.
I have used the vector map recently on a urban planning project. An AI file mapped on a terrain.
It initially posed some problems with net rendering on an external render farm, as it seems to not use max's standard file I\O system, and all the slaves rendered the vectormap icon\thumbnail over the whole terrain even though the texture path seemed correct. The guys at Rebus were great and fixed this shortly with a small script for max, and setting an option in the preferences dialogue "save strings in legacy non-scene files using utf8".
When it worked, it actually worked quite well, but I did notice that DR was having slight hiccups, where buckets would render areas with the map fine, and suddenly all of them would pause slightly before continuing.
The biggest issue I have with it now is its "filtering\mip-mapping" is not so good. It is painfully obvious when animating a camera moving towards or away from this texture, resulting in sudden\sharp borders between the mip-maps where line thickness is also affected slightly. Also glancing angles makes the map look like a blurred game texture from the original xbox. Not sure if this will ever be fixed, as Autodesk has a shady track record with fixing their own stuff, and adobe also seem to hate their customers. Not sure which company is responsible for maintaining this map.
To conclude..... its fine if you are going to use it on surfaces not slanted too much away, and that stay at a reasonably steady distance.Signing out,
Christian
i am so fed up with max2013...so i am desperately waiting for the vray Sp to appear.Martin
http://www.pixelbox.cz
