is vray in use on another computer? oh. and blur the liscence code a bit more and re-upload the image
VRay 1.45.70 beta build available
vince_1972,
i have exactly the same problem with the auth. server on another machine.
i got a new code for my local machine, now it works.Marc Lorenz
___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
www.marclorenz.com
www.facebook.com/marclorenzvisualization
Re: Testinstall
Originally posted by grunzelAnybody knows how to install the beta for testing, without touching the "normal" version?
Copy the 3ds max folder with a different name
Now during 1.45.70 installation point the newly copied directories.
Create a new direct acces labelled 1.45 that points the new 3ds max with 1.45.70 directory.
So I have good old 1.09.03r + 1.45.70
Only thing is Backlburner still points old 1.09.03r install.
Fermí
There seems to be an issue with some users who have Windows XP Home. WinXP Pro should work ok.Alejandro Gonzalez
alejandro.gonzalez@zerofractal.com
Zerofractal - Visual Communications
New Website! www.zerofractal.com
of course we are not running windows xp home in our office. that's not the issue.Marc Lorenz
www.marclorenz.com
Originally posted by BLADEWell, first thanks for giving us at least a beta. My question is:
I have a peer to peer network where one PC acts like a MickeyMouseServer. This machine runs day and night and this machine would be the best place to install the Vray license.
The problem is, that this machine don´t have any 3dmax on it and I can´t install the vray license on it. So I have to install it on an other PC with max and have to run this PC (for Vray license) + my MickeyMouseServer (for textures and so on) to run VRay with max on another Workstation?
Greetings
BLADE
Also you'd want to add a shortcut to it in the startup group so that it starts when you boot the server, or make it load as a service with one of the programs that can do this.Torgeir Holm | www.netronfilm.com
you can use the windows scheduler to run an app at boot time. so you dont have to log-in, as with autostart apps.
it would be more elegant if the license server was a real service though.Marc Lorenz
www.marclorenz.com
pour le pare-feu Xp, une petite recherche dans l'aide de windows en tapant pare-feu. Si il est en marche coupe le et réessaye de lancer vray
J'ai eu le meme problème: new connexion, closed connexion, Vray utilisant TCP/IP, mon pare-feu (Kaspersky) le bloquait. Et pourtant je n'ai qu'une machine.In teapots we trust.
