VRay 1.45.70 beta build available
  • #46
    si tu mets le server et le client sur la meme machine ça marche ?
    In teapots we trust.
    • #47
      non, rien à faire
      Architecture & design Sàrl
      global solution for architecture
      www.architecture-design.ch
      • #48
        quand tu mets les 2 sur la meme machine, tu mets bien localhost dans le champ vray license server dans vray authorization ?
        • #49
          oui, je fais comme Vlado l'a expliqué
          • #50
            alors la j'ai plus d'idée.
            • #51
              Merci quand même
              • #52
                Hi Vlado and Peter,
                I hope haven't missed an obvious answer from the threads above but here's my question regarding floating licenses.
                I'm running 3 network licenses of Max 6 over a server hence I purchased 3 advanced licenses from you guys. I've installed Max onto 8 machines and the network license makes sure I never use more than 3 licenses. I'm sweet.
                With the new build, should I be installing vrayserver on the machine that's hosting my Max licenses and then point all my client machines to that computer? Eg, the computer name for the sever is EvBackup01. I get a auth code for that machine, then I type in the same name as the host for all my other machines?
                Thanks.
                SunnyC
                • #53
                  The V-Ray license server can be hosted by any computer on the network, regardless of whether or not Max and V-Ray are installed on the that computer . The license server will generate it's own authorization request code, you can then ask to have your current licenses combined to authorize the server with the multi-license. Some considerations as to where to host the license server are that the server will always have to be running to use V-Ray and if you will be using more than 10 licenses , then you would probably need to host it on a windows server OS to allow for the extra network connections. This is assuming that the renderer maintains a continual connection with the license server, which I am guessing.
                  Eric Boer
                  Dev
                  • #54
                    Hi!
                    Are you guys planning on releasing max 4 version of this beta?
                    best regards,
                    Mare
                    • #55
                      Authorisation
                      What is the general waiting period for this?
                      Send my request early Friday (well for where I am located anyway).
                      Thanks
                      • #56
                        The usual waiting period for authorization is very short. However, I suppose this situation is differernt since everyone is requesting at the same time. I suppose you will get a reply soon though, now that the weekend is over.
                        Torgeir Holm | www.netronfilm.com
                        • #57
                          I had no issue getting an auth code during the week. Its a bad idea to ask on the weekend, Ive had bad luck with that.
                          • #58
                            Code
                            Well I wait till Wed morning, if no luck I will resent.
                            • #59
                              I can't say enough good things about the boys over at Chaos.
                              Sent my request for a key and got it overnight (I'm in Australia).
                              Mind you I haven't been into the office to test it yet. But I'm still
                              one happy camper.
                              Cheers to you Vlado, Tedi, Peter.
                              SunnyC
                              • #60
                                Im not a happy camper. I need a auth for 1.09 and i cannot get one. I have a mobo prob. new mobo, new harddrive reinstalled o.s. I sent an email on the 28th no auth code. Sent another on the 2nd. no reply yet. Now i am alteast a week behine on my project becuase i cannot render!!!!!!!!!!!!!!!!!!!!!
                                I love the software, but this emailing for a auth code sh!t needs to go!
                                travis
