VRay 1.45.70 beta build available
  • #76
    i had a problem with an app called netlimiter.
    i had to uninstall it completely in order to be able to use the new vray auth. server.
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
    • #77
      Will VRay motion blur ever work with a renderable spline?
      - Geoff
      • #78
        speaking of renderable splines, i'd love to see vray toon supporting spline rendering with pixel width.
        Marc Lorenz
        www.marclorenz.com
        • #79
          It works even now, if you uncheck the "Adaptive" interpolation option for the spline (if you have the spline animated, of course).
          • #80
            So I am in the same situation as Sunnyc1 where I have a license server running with Max and VRay. We only had 1 license of VRay advanced and just recently upgraded to 3 licenses...
            How do I upgrade my current license server to have a 3 multi-license setup? Do I need to request an auth code that allows for more than one license? Any help would be EXTREMELY helpful!!!
            Thanks all!!
            Troy Buckley | Technical Art Director
            Midwest Studios
            • #81
              Yep Donald, just send a request to have the licenses consolidated.
              Eric Boer
              Dev
              • #82
                As ReRender said. Just send your request to Tedi at Chaos.
                They are extremely helpful and will no doubt sort you out as
                promptly as I have been.
                The license you get back from is just super long. It looks like the string of
                numbers contains 3 licenses in it's length.
                SunnyC
                • #83
                  Thanks Sunnyc1 & RErender!!
                  E-mail has been sent and waiting for the new codes.
                  Midwest Studios
                  • #84
                    when will a new bugfix build be released?
                    and how many builds do you think before v1.5?
                    thanks.
                    • #85
                      Actually, I have had a request in to consolidate our licenses for a few days. I have not had a response from Tedi or anyone else for that matter.
                      I was wondering if I had made an incomplete request. For instance not having an authorization code. But we were already given a license for a single seat. I assume there is no other auth code needed.
                      @Donald2B: Were you granted a new license file?
                      Does anyone actually have the floating license system working for consolidated licenses for version 1.45.70?
                      Regards,
                      Corey
                      Corey Rubadue
                      Director
                      Chaos Group
                      • #86
                        @Corey: Yeah, I got an auth code back from Tedi very quickly. I also ran into another problem with the licensing system though. I had upgraded all of my workstations with a newer beta version and forgot to update the license server...so my code didn't work properly. Tedi got me straightened out and things are working better than ever!!
                        Midwest Studios
                        • #87
                          Good to know! Now you make me wish this consolidation to happen that much more!
                          Help Tedi, help!
                          Corey Rubadue
                          Director
                          Chaos Group
                          • #88
                            Can you make a demo version of 1.45.70 ??
                            Im in desperate need for a good displacement renderere but what i have yet seen is rather dissapointing.
                            It maybe works for simple roofs, walls or meshsmoothed objects of some kind but i always find something that will not work or gives me strange results (disturbed geometry).
                            Thats not only true for V-Ray, finalRender is also not able to render clean results in any cases.
                            I will not buy a renderer only to be frustrated when i get a halfdone feature.
                            • #89
                              If you are unable to get clean results with two different high-end rendering solutions that other people have great results with, odds are that it isn't the fault of the rendering engines...
                              • #90
                                you obviously have no clue about fR limitations.
