Vray6 - Forestpack V7.4.3 - Different Results
I think I found the problem. If anybody runs into a similar issue, seems with the update of both plugins, for whatever reason Forest Pack made alpha not fuctional on the old vray material. I recreated the grass from scratch and now its matching again.
Not sure which causes the problem, but thats the solution.
What do you mean with FP made alpha not functional on the old vray material?
Which is/was correct?
Originally posted by Vizioen View PostWhat do you mean with FP made alpha not functional on the old vray material?
Originally posted by RedStar View Post...No clue why this happened but it happened on 3 completely different scene files with different grass elements/textures.
- Likes 1
Did you test the geometry if it worked without being in a FP object?
This sounds like a huge bug though.
Originally posted by trick View Post
Make sure to report this to Itoo, bacause it can be very annoying to assign new VRay materials to all geometry that has alpha maps assigned!! (I am thinking of collections of Maxtree, Globe plants, etc, etc)
I will have to explore my other scene files to see if maybe it was a unlucky glitch in the 3 scene files that I was working in currently, but if this does happen on all old scene files this can become a long time consuming process to revise materials with alphas.
Originally posted by RedStar View Post...but if this does happen on all old scene files this can become a long time consuming process to revise materials with alphas.
Me starts itching Certainly a reason to wait for a solution. There also are lot of libraries out there that use Forest presets and/or alpha mapped geometry, so it is important where exactly this error is coming from. I mostly wait a few months before switching to a new version, so can't help.
So I looked at some of my other heavy FP scene files and they seem to be fine as well. No idea why some of my other assets got weird. I did however figure out what is causing the opacity slot not to work. Its the "Fog Color". Somehow on the files with issues, the fog color is black instead of white.
I did however figure out what is causing the opacity slot not to work. Its the "Fog Color". Somehow on the files with issues, the fog colour is black instead of white.
I tested a simple scene with a leaf (opacity) and latest versions of V-Ray and Forest Pack but everything seems fine. However if I set the fog colour to black, the opacity affected areas then renders black but this is expected.
- Likes 1
I don't know whether it's related but there was this post which flagged a bug https://forums.chaos.com/forum/v-ray...s-fully-opaque
Could it be that between versions the fog default colour was changed, thus causing an issue?
Originally posted by fixeighted View PostCould it be that between versions the fog default colour was changed?
Interesting thread, please keep any finding coming.
Lele
emanuele.lecchi@chaos.com
Disclaimer:
