VRayBitmap Viewport Texture Previews - 6.1
  • VRayBitmap Viewport Texture Previews - 6.1
    After the 6.1 update VRayBitmap textures don't show up in the viewport any more. Toggling the "Show Shaded Material in Viewport" has no effect. Regular 3ds Max Bitmap materials show up fine. I noticed in the new features list there's the line: "Deferred loading of the VRayBitmap viewport previews". What does that mean exactly? Is there another way to show texture previews? This is obviously a big deal when it comes to texture mapping. Surely I'm missing something obvious.
    Paul
    Yeah same here, they show up initially but as soon as you change one parameter the viewport textures disappear and the the model turns grey. No issues in 6.0. After rebooting 3Ds Max it’s fine until you change a parameter again, then same thing again
    Check out my FREE V-Ray Tutorials
      Hello,
      Thank you for the quick feedback. I managed to reproduce the issue and prepared a note for our developers to look into.
      Philip
      Philip Shounev
      QA department
      Chaos
      philip.shounev@chaos.com
        same as JonasNöll​ issue, 3ds max bitmap work ok
        Jackie Teh
        3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.05 build 32872]
        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
        Website: https://www.sporadicstudio.com
        Email: info@sporadicstudio.com
        YouTube: https://www.youtube.com/c/SporadicStudio
          It works when showing realistic materials, so a temp workaround until a fix maybe.
            same issue , .............. hope to get fix soon
              but the texture looks brighter
              Jackie Teh
                Hello,
                Sorry for the inconvenience - we'll try to get a fix very soon.
                Yavor
                Yavor Rubenov
                V-Ray for 3ds Max developer
                  Oh, that's odd. For me it is basically a 1:1 match.
                  I don't normally use that method though, as it takes longer to update in the viewport, so it's not anything but a workaround, other than reverting to 6.
                    Works! Never used that before. Thanks for the workaround.
                    Paul
                      I thought I was doing something wrong. That's quite annoying. And no realistic materials for me ever, very slow performance like that. Flat shaded all the way.
                      A.
                      www.digitaltwins.be
                        I had to install the older version due to this issue. Looking forward to the fix.
                        Aleksandar Mitov
                        www.renarvisuals.com
                        office@renarvisuals.com
                        AMD Ryzen 9 9950X 16-core
                        96GB DDR5
                        GeForce RTX 3090 24GB + GPU Driver 566.14
                          Today's stable nightlies (https://nightlies.chaos.com/main#/vr...e_6.1/20230217) have a fix for this issue.
                          We need to fix one more issue (possible crash when opening scenes with many bitmaps with viewport preview).
                          Yavor Rubenov
                            I had a scene with an object isolated in previous build. When I unisolate it starts compiling shaders and just freezes Max with latest stable nightly. Going to roll back to previous stable and see if it's the same problem.
                            Edit: It works in hotfix 3 so defo the update at fault
                            A.
                            www.digitaltwins.be
                            • #15
                              Hi, with the latest hotfix it seemed to have fixed the disappearing of the textures.
                              However some stuff still behaves quite weird:
                              - When playing with the Offset Parameters in the Coordinates Tab the viewport preview turns black for a while
                              - When the Overall Multiplier is anything else than 1 the wrong brightness is shown. For example 1.1 is much darker than 1.
                              - Same with Render Multiplier
                              - Setting the Filtermultiplier to anything else than 1 fades the texture in the viewport to a very dark version
