last bucket taking forever?
  • #61
    The problem is - rendertime per frame rises from frame to frame. DR with 40nodes - from 1.5 minute to 40 minutes (buckets just stuck for ages; with backburner - maximum rendertime was 4hours per frame, but the frames is a simple turntable-like animation). BF+LC (from file). 2.0 sp1 max 2012 sp2. It is something in scene, because using rebusfarm we got the same shite.... Almost ruined the project. Had to revert to BF/BF. I can send the scene to you on monday, but it is a confidential project... Maybe I can send only some parts ?
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
    • #62
      So long as I can reproduce the problem here, part of the scene is fine too, although we can also sign an NDA if necessary.
      • #63
        It is 250mb packed with .rar
        Any ides where to upload it ?
        CG Artist
        • #64
          Email us to vray@chaosgroup.com and our support guys will get you the ftp info to upload it (please mention this forum thread as well, so that they know what it is about).
          • #65
            Hope they will delete a scene, as soon as the problem get solved
            Done.
            To reproduce the issue - you need to go to the frame, where the device opens.
            CG Artist
            • #66
              Thanks for the scene; while we are trying to reproduce the problem can you also get me a mini dump from the 3dsmax.exe process while it is still stuck on the last bucket, just in case we fail to reproduce this?
              • #67
                Hm. Mini dump ? While it renders ? How ? Or you mean create dump file via task manager ?
                CG Artist
                • #68
                  The ones from the Task Manager might be a tad too large; Process Explorer can generate smaller mini-dump files. A mini dump would tell me exactly where it is stuck. Also, which frame # is "where the device opens"
                  • #69
                    Same problem again right now. Very, very huge file + tons of proxy, textures etc... it's an exterior. It's a complex mountain, 3500x2500 px - Render on one node. BF + LC - Spiral buckets behaviors from the exterior to the center + vrimg. One of the twelve buckets is stop in the middle of the image from 2 hours under a simple evermotion tree. In the scene we have 100.000 tree, due Multiscatter object. The CPU usage is 8-9% boh...
                    Vlado, I know. You cannot do nothing without the file...
                    www.francescolegrenzi.com
                    VRay - THE COMPLETE GUIDE - The book
                    Corona - THE COMPLETE GUIDE - The book
                    --- FACEBOOK ---
                    • #70
                      If you can get me the mini-dump file from the Process Explorer, it will be very helpful... unfortunately we very rarely can reproduce the issue here even you get us the scene.
                      • #71
                        It doesn't have any specific frame, where it stops. You have to render a few frames. I set the correct render range in my scene. Will try to create a dump... But not sure I have so much time to spend.
                        CG Artist
                        • #72
                          The dump will help, if you have time to make it. Other than that, I doesn't seem to hang here, but I'll try a few more times.
                          • #73
                            It doesn't hang using DR ?
                            CG Artist
                            • #74
                              I am having this issue. Has anyone figured out some possible solutions? The last 6-8 buckets seem to hang forever even on a 2 minute render. At the hang point i check the task manager and there is 0% CPU usage and 32% Phyical Memory usage (20gb on workstation, 4gb on slaves).
                              5 render slaves - All are Dual-Quad core Xeon, Win7 64 Bit, Max2012, Vray 2.
                              Renders great until the last handful of buckets (sometimes the buckets are my workstation, sometimes its a slave). Seems to always be one render machine (8 buckets are hanging). No idea what to do!? Please help.
                              • Dual 3.47 ghz Hex Core Xeon CPUs; 96GB Ram; SSD Drive; 3dsMax 2020; V-Ray; Sketchup 2020
                              • Love these Plugin/Scripts: ForestPro, RailclonePro, Soulburner, Populate Terrain
                              • #75
                                I have had this problem, and reported it awhile ago. If I restart the service, of the machine that is hanging, it'll complete the task.
                                Bobby Parker
                                www.bobby-parker.com
                                e-mail: info@bobby-parker.com
                                phone: 2188206812
                                My current hardware setup:
                                • Ryzen 9 5900x CPU
                                • 128gb Vengeance RGB Pro RAM
                                • NVIDIA GeForce RTX 4090 X2
                                • ​Windows 11 Pro
