Problem with blotches on interior
  • #16
    Hey tricky, ive just noticed your from the south east, where are you based ?
    Natty
    http://www.rendertime.co.uk
    • #17
      Oxford, which is apparently too short to use as a response on this forum!
      Kind Regards,
      Richard Birket
      http://www.blinkimage.com
      • #18
        tricky, if u can by any chance re-run a test with ur settings just changing the adp amount in the dmc sampler rollout to 0.85?
        i seem to skip this when switcheing from bruteforce to irmap wich usually leads to these kind of inconsistences in the gi
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
        • #19
          if you global subs are set to 0.01 to make everything 1, this will also mean you hemispherical subdivs are 1.
          Set hemi's to 1000 (1000x0.01=10) and see if that helps. But i think it would be better to just reset Vray and stick with default IR settings... high then -5 / -1 works well. Global subs at 1.
          • #20
            Is that correct? I guess you are very right there!!!! I never thought about that. I'd used a hybrid of some training video (cpnicholls???) but he always used bruteforce. I switched to Irmap for 'speed' purposes, but as you say, in doing that, I am probably multiplying the subdivs to 1 as well!
            Kind Regards,
            Richard Birket
            • #21
              If I get a chance, I willdefinatly do ythat. The deadline is the end of the day!! Yikes!
              Kind Regards,
              Richard Birket
              • #22
                @natty, do you guys happen to use catmull aa for animation as well. cheers
                • #23
                  Natty - I get the feeling everyone will be using your settings from this thread forward
                  Kind Regards,
                  Richard Birket
                  • #24
                    @tricky, i ended up trying your method with the global subdiv set to 0,01 as well but this ended up with blotches. reseting to 1 gives better result but slower to calculate. setting halfways sounds like a good choice as well
                    • #25
                      Yes, I think Steve Ellis in his earlier posting hit the nail on the head with the problem. I was basically being thick and stoopid!
                      Kind Regards,
                      Richard Birket
                      • #26
                        Everyone are welcome to use my settings, thats why i posted them.
                        But as far as im concerned there is nothing special here, just stable good settings.
                        N
                        Natty
                        • #27
                          How did it work out for you in the end ?
                          Natty
                          • #28
                            N
                            indeed. Looking at those settings, those are just good reliable settings. Pretty much what I use. The whole 'universal' settings seems wonky to me.
                            • #29
                              Agreed, don't try to fix something when it isn't broken in the first place... my theory ..
                              Natty
                              • #30
                                Natty, do you these settings for animated interiors ? If so, how well does it work (quality vs rendertime) ?
                                Regards,
                                Mike
                                http://mikebracken.cgsociety.org/gallery/
