It's been a long time since I had this issue. I have an image that is stuck on 1/2 dozen buckets. Nothing special about the scene and the buckets are not sitting on anything out of the ordinary. I am going on 27 minutes now, with things stuck.
Stuck Buckets
Stuck Buckets
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am not sure. Visable is default, so I am assuming it is visable. If things muck up again I'll check. I am trying again, with my original setting because nothing I tried made a difference. The place that got stuck on each try is no longer stuck, so I'll let this one run. I'll report back.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Those 4 buckets, under the Honda logo, are consistanly stuck. Althought the scene isn't done, the random buckets you see in the field, will not move. I'll let it bake for awhile, but seriously, this is insane. New client, first project...sucks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Have you done a vray scene convert?
Show me your settings?
Or send me a scene? I have time to look now.
just curious what are your settings dmc wise? Are you using light cache for gi? Here are some quick suggestions.
Lower dmc to something low and see if it still hangs, if it does -
Turn off lc and switch to bf/bf
turn off mb
turn off gi if all else failsDmitry Vinnik
Silhouette Images Inc.
ShowReel:
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Try turning off reflective caustics.
What does your sample rate pass look like?
Here is the model, however, it's not with textures or proxies. Also, on a note, motion blur and depth of field is on.
https://files.acrobat.com/a/preview/...b-9a45ae58f322Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Turning off reflection caustics got me past those 4 consistanly bad buckets. I'll let this run for a while.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby also turn on your "override depth" in global switches.
That should speed things up a fair bit
