Great! it's not just me
MAX 2017 Freeze
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
I am pretty sure I do have SP1, but I'll check.Originally posted by svetlozar.draganov View PostWe have noticed that the issue does not persist with SP1.
Would you please check if you have SP1 installed and if not to install it, run the same tests and notify is if the issue is still there?
Looking forward to hearing from you.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Yes, I have SP1 and this is still happening. Is it a MAX thing or a V-Ray thing? I have the latest nightly.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Maybe you're just too much in a hurry? With small projects, you can click click click and go nuts and the pc (and max can keep up).
I've found for years already, the larger the scene (when it hits like 30mil polys) then you have to be patient with max, otherwise you will get these hanging issues between simple operations.Kind Regards,
Morne
No, this is a simple scene with a physical camera. If I try to copy the camera, MAX freezes and I have to crash MAX. I am copying by using the shift key and dragging. It only happens on the camera. After I crash MAX and come back in, it'll work, but If I try again, it'll crash again.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostNo, this is a simple scene with a physical camera. If I try to copy the camera, MAX freezes and I have to crash MAX. I am copying by using the shift key and dragging. It only happens on the camera. After I crash MAX and come back in, it'll work, but If I try again, it'll crash again.
1) Group the camera and target - then copy with shift
OR
2) Switch "Targeted" OFF - then copy with shift
Same issue?Kind Regards,
Morne
Support was able to reproduce it, so maybe they know what's up.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostSupport was able to reproduce it, so maybe they know what's up.
Great, thanks!Bobby Parker
phone: 2188206812
- Windows 11 Pro
