MAX 2017 Freeze
    Great! it's not just me
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
      The issue is considered as a bug, and sent to our developers for further investigation.
      I'll keep you posted in case of any updates.
        We have noticed that the issue does not persist with SP1.
        Would you please check if you have SP1 installed and if not to install it, run the same tests and notify is if the issue is still there?
        Looking forward to hearing from you.
          I am pretty sure I do have SP1, but I'll check.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Yes, I have SP1 and this is still happening. Is it a MAX thing or a V-Ray thing? I have the latest nightly.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              Maybe you're just too much in a hurry? With small projects, you can click click click and go nuts and the pc (and max can keep up).
              I've found for years already, the larger the scene (when it hits like 30mil polys) then you have to be patient with max, otherwise you will get these hanging issues between simple operations.
              Kind Regards,
              Morne
              • #22
                No, this is a simple scene with a physical camera. If I try to copy the camera, MAX freezes and I have to crash MAX. I am copying by using the shift key and dragging. It only happens on the camera. After I crash MAX and come back in, it'll work, but If I try again, it'll crash again.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  Yes thats weird. Could you do 2 tests maybe (just for testing)
                  1) Group the camera and target - then copy with shift
                  OR
                  2) Switch "Targeted" OFF - then copy with shift
                  Same issue?
                  Kind Regards,
                  Morne
                  • #24
                    Support was able to reproduce it, so maybe they know what's up.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      We are still working on this issue and hope to have some good news soon.
                      Tashko Zashev | chaos.com
                      • #26
                        Great, thanks!
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
