Mud Rendering
  • Mud Rendering
    I am getting a very muddy render and an error that I don't understand. I reset V-Ray and restarted MAX, but the error continues. I can render with RT on the CPU just fine. I tried both IRR+LC and BF+LC, but both are muddy. What am I missing?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The warning in the vray info dialog? Could that be causing it?
    Colin Senner
      That's my question. What does it mean? My min and max are set correctly.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Found it! Some stupid rouge material.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Still having a muddy mess, so it wasn't the material. RT CPU and Progressive is fine, but bucket rendering is broken. Everything is default and I can raise my max subdivs to 100 and noise threshold to .003, but it is still a muddy mess in my shadows and anything dark. I do have a small window with vray sun/sky.
          http://screencast-o-matic.com/watch/cDl13bQDTm
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I would use progressive, saving out each render element, but I use PSD Manager, which doesn't work with progressive.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I was going to say megascans studio makes some great muddy ground maps!
              (but its not that)
              thanks
                Have you tried resetting your settings, merging into a new scene and hiding the glass material?
                A.
                www.digitaltwins.be
                  Yep, tried it all.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    You can use Progressive and save the render elements, but not the psd-manager masking features - because V-ray does not provide deep data when rendering progressive.
                    Daniel
                    Daniel Schmidt - Developer of psd-manager
                      Daniel
                      PSD Manager creates masks based on deep data ?
                      Available for remote work.
                      My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                        Yes, V-ray provides deep data via the G-Buffer and psd-manager extracts anti-aliased masks for everything you want (3ds max layers, objects, object-ids, material-ids.) You can easily do hundreds of them. Something that would take huge amounts of memory via MultiMatte render elements. For example you can simply type "1-100" into the Objects-ID edit field of psd-manager and are done. You will always have a mask for each object-id you applied in the scene available and only for stuff that is actually appearing. Photoshop is very efficient with many layers/channels that cover just a portion of the frame - so that is also easy to handle in post.
                        Daniel
                          I use layers for everything, so all my layers are masked. Each layer is a material or color. I can't imagine doing this any other way, at least proficiently.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            The term layer is always confusing when speaking of Photoshop and 3ds max at the same time. You mean you organize your 3dsmax layers based on the material or color the objects have. Then just have psd-manager create masks for all your 3ds max layers?
                            • #15
                              ******had to remove the video to NDA****** PSD manager for MAX 2017 is still in beta.
                              I recorded my screen showing how I use it.
                              http://bobby-parker.com/architectura...er-and-3ds-max
                              I just purchased Camtasia, so I'll probably be recording more often. Let me know how the quality is (audio and video). The software is expensive, so I better use it
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
