Proposition about Vray lights
  • Proposition about Vray lights
    Hi. There is a little proposition about Vray lights. Lots of users of other r/s often say about pour Vray shadows when you use Vray light at the window area in interior scene. Some times some objects are "flying in the air". I tried to solve the problem using Max's Photometric Free Area Light insted of Vray light. When you render the scene using IRR maps and direct in the secondary bonces It works even better then Vray light. To get good shadows you can simply set up thair size and softness not changing the size of the light. You get beautyful strong shadows.
    But Free Area Light need a little correction at the corners that are at the window. And it does not work good with photons. Here is the scene I used
    Free Area Light with photons. First I put Vray Light at the window and render photons to a file (save it as file) Than to get good shadows I turn off Vray Light and turn on Free Area Light and read photons from file (made with Vray Light). I was not able to get this kind of shadows using Vray light. And as you can clearly see there is an impression that Free Area Light gives you more lighting. SO area light is much faster
    and need less subdivs. Thanks
    http://vr.reaperfields.com/images/the%20best.jpg
    this is very good for vray free users. Thanks for the tip!
      Where can I find this Free Area Light?
      Thanks,
      --Jon
        lights tab/photometric/free area
          actually i dunt think there's any problem wit "floatin in the air" ...i have seen these situations in real life........many many times actually.....if u look carefully around u ....some object do look like floating....the usual reason for this is that light is dim and very diffused....like a dim lamp shining down at an object located far awar from the lamp.....
          i think it really depend where u put the light.....if it's floating...i think it's "physically accurate"....
            there is maybe one more point, I tried this stuff out, however the irradiance map were rendered so much slow, when I turn on area shadows. Dont know why
              Do not try to render scenes with Area Light if you do not know Vray best.
              It is a little difficult and It can even make your result worse. I just want to explane what I wanted to say:
              If you want to get strong and clear visible swadows, using Vray light, you need to decrease it's size. BUT it is not correct at the window area.
              Area Light allow you to control the size of the shadows independently of the size of the light. And Area Light is much faster than Vray Light. I will explane WHY:
              Than more size Vray light have than larger and less clear the shadows become than more subdivs you need for the light to make the shadows good looking. And you are not able to control the size of the shadows.
              With Area Light you can make the shadows any size you want. And when the shadows are quite clear thay need much LESS subdivs
              This can be useful to create a light in Vray program that uses the same
              calculation algorithm. But it need a little improvement - from Vray light.
              Vray Light and Area Light can be combined to another light
                I see now, I'm working in an older version of MAX. Thanks anyway, I thought it was a free third party plugin
                --Jon
                  eh, I just read again your first post, now its clear. I missed the point the u used pmapping.
                  All right now
                    Hi Alkonst,
                    Very interesting thing,
                    Congrats !
                    Gael
                      I render IRR maps and Fotons using Vray Light than I turn Vray Light off and turn on Free Area Light FOR FINAL RENDERING and IRR maps and Fotons I read from file.
                      All you need - to attune the multipliers of Vray light and Area Light
                        I tried to observe real world shadows coming through a window and now I understand that they are quite different from Vray light shadows unfortunatelly. Real world shadows are much more expressive and stronger then Vray light shadows. Of course the beauty of Vray picture is good but the shadows really need lots of improvement.
                        And real world lighting never decay like INVERSE SQUARE Vray light!
                        The AIR always helps rays to extend the light intensity much further then INVERSE SQUARE tipe gives.
                          skylight or sunlight ?
                          Eric Boer
                          Dev
                            to rerender
                            to rerender
                            I think VRAY light at windows and its shadows
                            Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
                            https://www.facebook.com/essetreddi..../photos_albums
                              I meant what he was comparing to in real world.
                              Eric Boer
                              Dev
