[HOU-1581] V-Ray product suggestion: V-Ray TexCurvature, Scale Value can be Mapped
  • [HOU-1581] V-Ray product suggestion: V-Ray TexCurvature, Scale Value can be Mapped
    Hi Guys,
    When I try to use the V-Ray TexDirt to create edgewear grunge on convex edges, it comes with artefacts from the Normals.
    To get around this, I use V-Ray TexCurvature but, annoyingly, the scale value cannot be mapped with a grunge texture. My suggestion is to make this parameter mappable so we can generate edgewear damage to convex edges using grunge maps.
    Thanks
    Hello stevejjd , you could put the curvature into a V-Ray Mask and mask it there with any noise, image or user attribute you want. You can also use the output of this V-Ray Mask as an input for another V-Ray Mask and add more details on those edges. Is that work for you?
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      This works. Thank you. ~
      But I still think better results could be seen if the curvature map's scale could be mapped. I find the curvature radius is too sharp and uniform.
      The reason V-Ray's dirt texture is distinct from other render engine's dirt maps is because the radius can be mapped making it look like dirt is emanating from cracks and crevices. I think this will help the Curvature map look more natural.
      (Update)
      Oh look, the sample radius can be mapped. I think it’s working how I wanted. Try plugging a texture into a Color to float then plug that into the sample radius.
        Could you pls send me a simplified scene? Socket types are automatically converted export-time so I wonder why you need to use "color to float" manually...
        andrei.izrantcev@chaos.com
        Support Request
          https://drive.google.com/open?id=1nv...MrwLC_ayRL0mW9
          Here we go
          I made a scene file with a simple example.
            Tnx, will work without "color to float" in the next builds.
            Support Request
              Also can we get curvature in vray tweaked to allow the concave and the convex values as different ends of the output value? As in convex is white, concave is black, flat is grey?
                +1 on John's suggestion.
                always curious...
