Fog
  • #31
    Hey Vlado,
    Sounds good, but I'm having a hard time confining the fog to an area!
    So what is the proper shading network to use when you want to assign an environment fog to a piece of geo (like a cube or a sphere as a bounding volume) for the fog effect? And when you do it this way, do you need to plug anything into the environment fog slot in the v-ray for maya render globals?
    Thanks!
    • #32
      You can use the standard Maya way, and assign a volume material to the geometry. Or you can use global environment fog and assign meshes to it (it's a set).
      V-Ray/PhoenixFD for Maya developer
      • #33
        Here is an example with VRaySun and GI
        envfog.zip
        • #34
          ah! I was trying to apply it as a shader - this scene is very helpful. Thanks so much!
          • #35
            arghhh.... Couldnt get it to work..
            Had to untick cast/recieve/primary visibilty on the meshs shape node.
            • #36
              yes, you need to untick those in order to see the EnvironmentFog effect
              Zdravko Keremidchiev
              • #37
                Hello, nice scene bazuka!
                I was wondering how to achieve a texture to the fog material, to make it more "cloud like". I have been plugging in 2D/3D textures to the density but to no effect.
                Any ideas (without having to use fluids/containers)?
                Maya 2012 Vray 1.5
                Cheers,
                DM
                • #38
                  hi dm, glad i could help
                  ill try tonight when i get back home, and let u know
