Before and after
Im solely dependent on shave...and as you know its up to Joe to implement that code which may take some time. Current shave 7 can render vray mtl 3, but can't read colored textures so its not very useful for us as we have strong color variation.Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
i just test it, and maya crashes on 1st render hit, the only way i could render the shave was to render it 1st with software and then switch back to vray...
but that was not the only probl atm, i couldnt get the hairmtl3 in the render? i have apply shader to everything i could think of, and still nothing
maybe some hints? i have even try the what petrov said to connect to shading network, nothing.......Last edited by bazuka; 09-01-2013, 11:42 PM.
Hm, Joe tells that they should have fixed the crashing bug some time ago. In any case, they are about to release a new version with the latest changes in the code (support for hairmtl3, rt rendering and the above optimization for transparency). None of that has been there before.
VladoI only act like I know everything, Rogers.
Bauka, I had time to debug the crashing before they made a fix for it. Apparently the vray dll's which need to be present in order for shave to render with vray fail to initialize during maya start up. I declare the files using a cmd and env variables before start up and it would not work, unless I placed them into the vrayplugins folder. At that point it worked.
However v7.14 still didn't work with the textures yet...waiting on update...Dmitry Vinnik
ShowReel:
Originally posted by bazuka View PostDmirty my friend, i did copy shave dll's into vray/vrayplugins folder, so im still not sure whats the probl, coz in v12 didnt had any crashes
cheersSomething is going on as Vlado pointed out.
Dmitry Vinnik
ShowReel:
I can't get shave 7.15 working with latest nightlies Maya win x64 2013, joe said he was running vray 2.201. Which version are you running?
Sucks because the speed up is only recent builds, right? At least it's finally working for you. I'd be curious to know how to use hair3. Wasn't obvious to me.Last edited by Zach Gray; 14-01-2013, 11:48 PM.
