You need 2.2 and above for the Phoenix shader. If you want to choose the shader, you need a nightly.
I'm testing with vray 2.2 now and I don't see any speed up in rendertime. If I right out a vrscene then open it up it still says "EnvironmentFog fluidShape3@volume " . how I can I know for sure if its using the pheonix shader with 2.2
The nightlies have additional attribute to choose manually the shader, 2.2 and 2.3 use Phoenix if it can be found. If Phoenix is used for rendering you will see something like this in the oputput window:
[2012/Nov/15|11:15:25] V-Ray: [PhoenixCachePlugin] Frame data successfully loaded from .
[2012/Nov/15|11:15:25] V-Ray: [PhoenixSimPlugin] grid 10x10x10, time 0.
Here is the the ouput window when I render a fluid .
Currently we're using the full version of Pheonix FD, not the demo. BUT, our LA branch is using the licences for pheonix. If I just try and sim with pheonix I get a " cannot obtain license " error. Would that be causing the problem with rendering maya fluids?
V-Ray: Starting render
[2012/Nov/15|11:45:25] V-Ray: Exporting scene to V-Ray.
[2012/Nov/15|11:45:25] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2012/Nov/15|11:45:25] V-Ray: Translating scene geometry for V-Ray
[2012/Nov/15|11:45:25] V-Ray: Total time translating scene for V-Ray 0h 0m 0.0s (0.0 s)
[2012/Nov/15|11:45:25] V-Ray: Rendering.
[2012/Nov/15|11:45:25] V-Ray: Rendering frames.
[2012/Nov/15|11:45:25] V-Ray: Updating frame at time 31.00
[2012/Nov/15|11:45:25] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 91 % completed
[2012/Nov/15|11:45:25] V-Ray: Total time updating frame 0h 0m 0.1s (0.1 s)
[2012/Nov/15|11:45:25] V-Ray: Preparing renderer...
[2012/Nov/15|11:45:25] V-Ray: Preparing scene for rendering...
[2012/Nov/15|11:45:25] V-Ray: Creating bitmap manager
[2012/Nov/15|11:45:25] V-Ray warning: Light cache is used for glossy rays; it is recommended to turn on light cache retracing.
[2012/Nov/15|11:45:25] V-Ray warning: Subpixel color mapping is on: rendered result may have incorrect brightness.
[2012/Nov/15|11:45:25] V-Ray: Preparing scene for frame...
[2012/Nov/15|11:45:25] V-Ray: Bitmap file "X:/oblivion_obl-2324/_library/assets/hdri/Set_HDR_From_DD/set02/hdr_radiation_zone_145n_0423_set02.0001.exr" loaded.
[2012/Nov/15|11:45:26] V-Ray: (Estimated time remaining: 0h 0m 2.9s): 35 % completed
[2012/Nov/15|11:45:33] V-Ray: Compiling geometry...
[2012/Nov/15|11:45:33] V-Ray: Tracing 250000 image samples for light cache in 24 passes.
[2012/Nov/15|11:45:33] V-Ray: Building light cache...
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.9s): 11 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.7s): 22 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.6s): 30 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.5s): 40 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.4s): 51 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.3s): 62 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.2s): 74 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 85 % completed
[2012/Nov/15|11:45:33] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 90 % completed
[2012/Nov/15|11:45:34] V-Ray: Merging light cache passes...
[2012/Nov/15|11:45:34] V-Ray: Light cache contains 2927 samples.
[2012/Nov/15|11:45:34] V-Ray: Prefiltering light cache...
[2012/Nov/15|11:45:34] V-Ray: Rendering image...
This is also at the top of the output window when I open maya
mental ray for Maya 2012*
mental ray: version 3.9.1.48, Dec *7 2011, revision 162457
PhoenixFD: API error detected in ./NodeSimulator.cpp (102 : (kInvalidParameter): Object already exists
[2012/Nov/15|11:52:38] V-Ray: V-Ray for Maya version 2.20.01 from Feb *1 2012, 17:09:48
[2012/Nov/15|11:52:38] V-Ray: V-Ray core version is 2.00.01
[2012/Nov/15|11:53:05] V-Ray warning: Successfully loaded "X:/oblivion_obl-2324/_library/assets/hdri/Set_HDR_From_DD/set02/hdr_radiation_zone_145n_0423_set02.0001.exr" for viewport environment !
You are probably using old version of Phoenix. Try the last one. The demo is also sufficient.
I have download the latest demo and installed. I am still using vray 2.2 and I still don't see anything in the output window that says im using pheonix shaders.It renders the same speed with pheonix fd plugins loaded and unloaded which makes me think its not using the shaders. pretty please I need to get this working asap
yes I have the plugin in my vrayplugins folder. The only things my output window says about pheonix is when I open maya or load the plugin.
Phoenix FD for Maya 2012, version 2.0.0 Beta from Nov 5 2012, 13:00:59, revision
PhoenixFD: loading C:\Program Files\Autodesk\Maya2012/phoenixfd/scripts/phxfdInit.mel...
OK.
Okay I reinstalled PhoenixFD demo. I can sim with Phoenix but It renders black/ no alpha with Vray, mental ray and maya software. Thats probably why maya fluids don't work. Is there something I am missing here? is there something I have to do to render after installing the pheonix demo?
I get this error
// Error: ERROR: Could not create plugin PhoenixFDSimGeom ! //
// Warning: Scene is empty. //
