Comping ACEScg renders in Photoshop
    Originally posted by Muhammed_Hamed View Post
    The one I named RRT + ODT above, uses the ACES tonemapping
    thank you.
    Marcin Piotrowski
    youtube
      Hi Muhammed, thanks for this tutorial. I'm having trouble getting this to work in Maya 2022 with OCIO ACES 2.0. Could you help? Many thanks. Lee. Click image for larger version
Name:	Screenshot 2021-08-27 at 14.29.56.jpg
ID:	1123365Click image for larger version
Name:	Screenshot 2021-08-27 at 14.30.20.jpg
        Hello wizlon
        Can you explain the issue in more details?
        I still use ACES 1.2 with Maya 2022, because not many applications yet adapted OCIO 2.0
        So for consistency between different applications I still use ACES 1.2 with an environment variable
        Here is a link to ACES 1.2
        https://github.com/colour-science/Op...ces-1.2-config
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Thank you Muhammed. I've also reverted to using 1.2 now. All is working fine now. Thanks again.
            Is it worth rendering to ACES if the renders in photoshop will be comped in adobe98 or sRGB, and at 8bit? Im not sure the person who I hand renders to wants to hear about ocio and workflow changes after their 20 years of retouching the same way.
            Website
            https://mangobeard.com/
            Behance
            • #21
              Yes, it is worth 100%
              Keep in mind that ACES affects lighting and GI, not just the tone-mapping
              You can burn the OCIO adjustment to an 8 bit Jpeg in the frame buffer then give it to him ?
              or collapse the stack in Photoshop then send him an 8 bit file
              Many places are working this way, but usually the high dynamic range adjustments are done in Nuke or Fusion before being handed to a retoucher
              Best,
              Muhammed
              Muhammed Hamed
              chaos.com
              • #22
                Ok cool. Burning in my Vray framebuffer corrections is something I do already since they want a simple 8bit workflow, so if this can apply to aces, then thats great.
                Website
                Behance
                • #23
                  Yeah, there is a checkmark for it
                  Muhammed Hamed
                  chaos.com
                  • #24
                    small addition to fnord's ocio plugin - two luts merged into one:
                    https://forums.chaos.com/forum/chaos...er#post1152687
                    Marcin Piotrowski
                    youtube
                    • #25
                      Thanks for sharing piotrus3333
                      I will test this today!
                      Muhammed Hamed
                      chaos.com
                      • #26
                        I notice photoshop now has an ACEScg colourspace, is there a way of using that to simplify the method a bit? Couldn't make it work myself.
                        I guess even if you specify ACEScg on new file creation, if it's 32bit the file should be linear (but with ACEScg primaries?) - and a 'hidden sRGB display transform? Nah, I'm lost... working space of sRGB or ACES doesn't seem to change the need for the 2 LUTs to get the right colour.
                        • #27
                          What version of Photoshop is this?
                          Cheers
                          Matt
                          • #28
                            Cheers
                            Matt
                            Version 24.4.0
                            • #29
                              Circling back to this.
                              How would this work if your in ACES but are using the un-tonemapped view?
                              • #30
                                "How would this work if your in ACES but are using the un-tonemapped view"
                                Thats how I work often. I just sling a tonemapper on the stack, and set it to Hejl-Dawson...tone-mapping space to ACEScg...not sure if its technically correct but it seems to work for me. Ill play with the shadow and highlight sliders depending on the scene. Maybe pop the gamma to 0.9-0.95 depending on what I need.
                                Website
                                Behance
